need help with pats
i got the motor in but it wont crank. mostly everthing hooked up. at this moment i have the 99 4.0 in with 99 wiring, 99 computer and all the 99 sensors. engine wiring harness is plugged into my 95 body wiring harness. have automatic shifter mechanism all bolted up to my 95 steering column. i have the whole steering column from the 99 sitting to the side. need to know if i can wire in the transceiver thru my 95 body wiring to send a signal to the 99 ecu.
also i cant find where to clip in a switch that i dont know what it is unless it is a park/nuetral saftey switch that is pushed in when the shifter is in park. it has three wires coming out of it. i believe the colors are orange/green/and maybe gray. i have to check on that. also i have read something about a jumper on automatics that plug into the clutch saftey switch. is that what i think is the nuetral saftey switch suppose to plug into?
one more thing. does anyone know how many parts are to the pats system. did i need to take the rad out of the 99.
