Leigh
- Jul 20, 2011
Been having an intermittent, "slightly" rough at idle problem since I bought the truck used two years ago.
All the spark plugs had been replaced just prior to my purchase.
I'm getting a Check Engine Code 0304, which is a #4 Cyl. misfire.
Trying to determine weather it's most likely sparkplug/s or Fuel-injector.
I would have tried swapping out the "plugs", but #4 is not the easiest to access!
I'm using a relatively inexpensive Actron CP9125 OBD ll Scanner. Would a more "sophisticated" scanner pin-point the problem?
I would think that with dual ignition/sparkplugs, sparkplug misfire would be less likely???
Best regards,
Leigh
Best regards,
Leigh
