- Jan 18, 2021
- Chattanooga, TN
- 4.0 V6
- Tire Size
- 235/75/15
- My credo
- Get the job done, correctly, the first time. There's beer to be had.
I feel pretty confident it's a vacuum issue. The reason is it only hesitates and bucks under light load. When driven at higher RPM or under load, it's much better, almost smooth. So I feel that it's not ignition or fuel filter related.
So, what could be causing this kind of thing in the vacuum system? Or if you've run into similar symptoms and it's not the vacuum system, what was it? I've got a new ignition system (coil pack, wires, and plugs) as well as a new ECU.
I don't want to start replacing things hoping that'll do it. Thanks all.
David
1998 4.0l 4WD 5spd ~225k miles
David
