Bajabronco
- Sep 5, 2007
- Age
- 36
- '98
I have a new to me 1998 ranger 4x4 ex-cab. 4.0l/5 spd manual. 250,000 miles on it. PO installed a k&n cold air intake and an aftermarket exhaust. He also had a hypertech programmer running when I bought it.
Check engine light was on when i bought it, pulled the codes: 171 and 174 (lean on banks 1 and 2) cleared them and ran through a tank with the truck still re-programmed. then the engine light popped for me, same codes, just wanted to check. Cleared again, checked vacuum lines and connections, cleaned the engine (pressure washer) and programmed the truck back to stock. Ran fine with no codes for 500-600 miles and 2-3 tanks of regular. Yesterday the light came on again, though this time it only read bank 1 lean, not bank 2 aswell. Today i checked my mileage at 15.5 mpg driving very nice with 1/2 city, 1/2 freeway.
Also, in the last week or so it has been hard starting cold, 5ish seconds of cranking over the usual immediate start.
Today I checked again for vacuum leaks with starting fluid, idle was steady as a rock, I checked the vac lines and the upper intake gasket.
So now I am thinking either the MAF of the fuel pump, though the hard starting is having me lean towards the fuel pump. I haven't checked fuel pressure yet. All I have right now for a pressure gauge is a good compression tester, though i may have to buy a fuel pressure gauge. Do you just check this at the schrader valve on the fuel rail? I have read it should be up around 40 PSI.
I drove it very easy for the 500 miles of no light, that also leans me towards fuel pump if i was never demanding much from it.
I will try cycling the key for the next cold start a few times and see if it starts quicker aswell.
Any insight would be greatly appreciated, both the MAF and the FP are big ticket items for me and neither are returnable once installed.....I would hate to replace the wrong one.
Thank you.
Thank you.
