turnbuckle
- Aug 25, 2007
- Automatic
I went bush crawling , came out and had no speedo , major hard shift , abs light on , & o/d light flashing.Pulled over checked under , no wires hanging or damage from the bush. Limped to the hiway and then everything went back to normal. One week later hot hot weather, one hour drive , & wouldn't shift at all, stuck in first. Next day , all was normal.
Replaced the ABS in rear end , all was fine for a week. yesterday was super warm , i jump in after work and back to hard shift wonky speedo & abs light.
Is this a sensor /heat malfunction ( i can pray for snow) or is there another sensor I can look at? Seems the ABS replacement was not the answer.
98 ranger 2wd 3.0 auto
