hoppy
*EDIT* the jerking/lurching was caused by the tps connector that was faulty, so we spliced a new one in and the jerking/lurching is gone, still have a misfire though, compression is GOOD 150psi+ for all 4 cylinders, and we're getting the injectors rebuilt, so hopefully that will solve the misfire problems
(original post)Symptoms are rough idle, misfiring throughout the powerband, and jerking/lurching while at cruising speed. When under heavy acceleration, it does not misfire, but under light or steady throttle it misfires and lurches.
We just finished rebuilding the engine, and a few months before the rebuild, we replaced the cylinder head which probably acquired 3-5k miles before the rebuild. It has new pistons, rings and gaskets all the way around and after getting the engine back in, it started first turn of the key, and the check engine light didn't come on until about the 3rd drive around the neighborhood, or about 20-25 miles or so.
We think the problem could be one of 3 things OR a combination of these 3 things.
1)The cylinder head could be defective, and the valves could be not sealing properly. (Solution would be to return the cylinder head (under warranty) and get a new one and hope that it's not defective)
2)During the install of the engine, the tie-down bent the connector on the coil for the compression stroke spark plugs (remember, this engine has 8 spark plugs, 4 for the compression stroke, 4 for the exhaust stroke), SO replacing that coil could/should help. (Solution would be to buy a new coil or 2 just to be sure to have 2 new coils instead of one old and one new)
3)The fuel injectors could be clogged, and need cleaning. (Solution would be to take them in and get them cleaned)
Also, I read this article (http://www.hotrodhigh.ca/2300Shockin.html), and tried swapping the 1&4 and 2&3 plug wires going to the coil for the exhaust stroke spark plugs, and it ran just as poorly.
Now that you know the background info, do you have any ideas about what the cause of the problem could be? Have you had similar experiences? What did you do to solve the problem? Are we anywhere close to figuring out the solution?
Also, after a full rebuild, we could crank the engine with a ratchet and with only 1-2 slow cranks we got 60-70 psi. this is with no break in, and at slow hand crank speed. I feel we have decent compression.
We rebuilt an entire engine because of poor running and a flat cylinder (35-40 psi) and it still runs bad.
It seems to run well, though, when stone cold. like the start up system does something to the spark advance or the injection mixture that goes away after 30-90 seconds.
