hoppy
okay, so here's all that we have done, some things fixed 'part' of the problem, but it still misfires like it's only running on 3 cylinders until it's at operating temp..:
Things we have done:
New Cylinder head (1 year old)
Rebuilt engine: new pistons, rings
-checked compression @ 150+psi/cylinder
Rebuilt injectors
New clutch
New TPS
Replaced Throttle Position Sensor connector (spliced in new wires, plug)
Replaced Idle Air Control Valve
Replaced both O2 sensors
New Cat
Replaced BOTH coolant temp sensors
Fairly new plugs and wires
Swapped coils from t-bird, to ensure that those weren’t causing misfire (same part#)
Swapped plug wires on intake side coil to 1-3 and 2-4 to make exhaust stroke plugs fire on compression stroke
Our only other ideas are some type of short or frayed/broken wire somewhere in the electrical harness OR a malfunctioning ECU. I'll be posting a 'want' thread in the for sale section to see if anyone has an ECU with similar numbers.
Rebuilt injectors
New clutch
New TPS
New Cat
