96 single cab "mtx thunderform" subwoofer(Installed)
looks WAY too tight.... what about excursion? aren't you hitting the seat??? can't be good for the sub at all
Well, it is a lil tight but i didnt worry about loosing an inch or two of leg room. And as for excursion, the sub has an O ring to prevent pushing the edge surround of the sub with the seat. The seat touches the O ring not the sub, and plus its just for a little thump not for Realm of Excursion... Thanx for your concern though.:icon_thumby:
coo. i new you would like it.. i love mine. and a new amp will make it that much better! :icon_cheers:
how much was your hid conversion kit and where did you buy it?
I bought them on ebay, $60, i bought the wrong kit though. You need the (Bixenon) ones. The ones i bought was the lo beam only, bixenon is hi/lo beam. Those run around $100 bucks. I recently removed mine cause of inspection, but they are definetely worth it...:icon_thumby:
96Greenster; if your headlights shine as low as the look in that one pic, get them aimed there WAY too low.
The "MTX Thunderform boxes" are actually made by Bass Slammer, and are designed in an almost perfect manner, fit, finish, and if you use the preloaded/powered versions, and follow the directions they will not hit anything.
http://www.bassslammer.com/products/vehicleSpecific/index.cfm
They look low but that just the camera. There actually too high, I get the flashing light signal as incoming cars get closer. Especially the the lift kit.:icon_thumby:
