2.3L ('83-'97) 96 Ranger 2.3L Constantly Switching from Open Loop to Closed Loop
ksimp
Forum Member
SC
Hi All,
My 1996 Ford Ranger with a 2.3L, 5 speed is having issues running. Sometimes it will not idle without holding the pedal down to around 1500 - 2000 rpm. When it does idle, if you push the pedal it will go dead. I hooked up an Autel scan tool, and I noticed it was constantly switching from open loop/drive to closed loop, back to open loop/drive to closed loop, etc. The fuel pressure is good 35 - 40 psi (new fuel pump). MAF, IAC and TPS look good (checked with Autel while engine was, barely, running). I can smell unburnt gas while it is running. Engine is also loping while it is running. Please let me know if there is anything else I need to test.
Thank you very much for your help.
Does your model have a fuel pressure regulator on the fuel rail? And it has a vacuum line going to it? Pull that vacuum line and see if it has fuel in it. I know the pressure is good, but I would still check it to make sure.
Yes, it has a FPR. I replaced it about 4 months ago. I noticed the vacuum line was thin and stressed on the end connected to the FPR. So, I replaced it with a thicker vacuum line. There was no gas in the vacuum line.
Thanks
Check it again to be triple dog sure. I do not trust new parts anymore.
There's several criteria it checks to go into closed loop, one is the signal from the O2 sensor, if it's old or original it would probably be worth changing.
Might be time to do a compression and possibly leak down test to check the general health of the engine, looking at the MAF reading is a reasonable thing to do but these things have a tendency of recessing valves...
Thank you all for your replies.
I pulled the fuel regulator vacuum line to double check for gas leaking from the regulator valve. It was dry.
While working with the truck, I noticed the CEL did not come on when I turned on the key. It used to work. I'd replaced all the bulbs in the gauge cluster with LEDs, and it worked afterward. I back probed a test light to the actuator wire (pin #2 - pink w/ light green) on the PCM connector with the other end on the positive battery connector. The PCM was lighting up the test light as it would the CEL, if the CEL were working.
I've had the engine out for a rebuild, and the wiring harness that is behind the EGR pipe had gotten toasty crusty. I removed the outer cover(s), and some of the wires (some of them run to the PCM connector) were melted. I repaired those wires, but something tells me they may have rubbed through. Looks like I'll be pulling the upper intake again to have a look at those wires. If that's the problem, I'm going to need to find a better way to route the wiring harness after it's repaired.
Hi Guys,
I started removing parts to get to the wiring harness in question, and I noticed the IAC did not appear to be very healthy. The spring that holds the valve was missing. I ordered a "Standard" manufactured model from RockAuto. It had the missing spring. I installed it. After very rough idle at first, the idle smoothed out. The truck now idles normally. It still has an intermittent stumble, and sometimes will die, when pressing the gas pedal about 1 inch. I've ordered a replacement "Standard" TPS.
Hello,
Replaced the TPS today, and it made no difference. :cautious:
I also connected a timing light to each of the 8 spark plug wires. They are all firing.
I keep noticing the smell of raw gas coming out of the tail pipe. My next focus will be the 3 non-new fuel injectors. I'd replaced #4 to try and remedy a miss-fire on the number 4 cylinder (which worked). The engine will idle, but as soon as you cut in the gas pedal, it tries to go dead. You have to pat the pedal to keep it running. If you ease off patting just right, it will settle down and idle. I'm guessing I may have one or more fuel injectors leaking. I'd already checked the fuel pressure. It was 30 - 40 psi engine off and engine running (new fuel pump). I need to re-connect the gauge and see if the injector(s) are leaking down fuel pressure with the engine off.
I welcome any other ideas.
And as always, Thanks for the help!
If the fuel level is low in the fuel tank, you could give it a strong dose of seafoam and then drive it and see if that helps clear up any sticking and half clogged injectors.
Thanks, franklin2. I did some checking with the Autel scanner, and the fuel is at 1/2 tank. Seafoam wouldn't hurt. Also, I noticed both upstream and downstream O2 sensors were reading a constant above .9 volts at idle. That's really rich. I'm going to try a fuel pressure bleed down test to see if one or more injectors are stuck open.
If the injectors are not introducing fuel into the engine like a fog, but instead sputtering and fuel is entering in liquid form, the engine will not burn the fuel properly.
Ok, the story thus far...
I measured the temperature of the exhaust and it went as follows:
#1 cylinder - 83*
#2 cylinder - 94*
#3 cylinder - 340*
#4 cylinder - 130*
So, I went on the premise that at least the #1 and #2 fuel injectors were bad.
I purchased a set of Denso (Ford stamped) F87E D2B from ebay. I used a fuel injector tester with a can of carb cleaner to test each injector before installing them. They all had a nice cone shaped stream. After installing, the truck idles like a champ. I let the engine warm up completely. I tried to take it around the block for a test drive, but as soon as you press the gas pedal, the engine dies. I had to hold it down about 3/4 to get it to crank. Then I had to keep patting the pedal to get it to run long enough to get it around the block and back to the house.
I connected the Autel scanner and watched the sensors while the engine idled. I noticed the upstream O2 sensor was pegged out at close to or at 1 V (see attached pic).
I'd replaced the upstream and downstream O2's with Denso units back on 10-24-2024. It appears the upstream has died. Is there a recommended upstream O2 sensor for the 2.3L? Preferably one that will last more than a year.
Thank you for all your suggestions
I'll keep plugging at this thing.
For now I think I would unplug the o2 sensors. The computer should look for them when it tries to go into closed loop, find out they are not there, and then just stay and run in open loop using the fueling tables in the computer memory. I would see how it runs like that, it should run mostly ok like that.
Thank you, franklin2 for the advice. I tried disconnecting both O2's. It didn't help. Now the truck will not idle. I have to keep playing with the gas pedal to keep it running. After a bit of reading, I surmised the upstream O2 may be carbon fouled and not able to read oxygen content. Thus the constant high voltage reading. I purchased a new NTK O2 sensor from Rockauto and replaced the upstream. I'm uploading a picture of the old one. It was very carbon fouled. The NTK O2 was reporting voltage normally.
Today, I pulled the plugs on the passenger side and performed a compression test. Results are as follows (engine has been rebuilt, rings are new):
#1 - 185 psi
#2 - 190 psi
#3 - 192 psi
#4 - 179 psi
The plugs were as carbon fouled as the upstream O2, so I cleaned them and regapped before reinstalling them.
The truck still will not idle. If I try to hold the RPM's at around 2000, the engine searches from about 1800 - 2300 rpm. When I let go of the gas the engine dies. I'm still open to suggestions, and I really appreciate any help.
When you first start the truck cold, it doesn't use the O2 sensors till they warm up. If it will not idle cold, something else is up.
Event Coverage
TRS Merch
