2.3L ('83-'97) 96 Ranger 2.3L Constantly Switching from Open Loop to Closed Loop
The only way I can see it running that rich on all cylinders is if the air is super restricted (like new filter still wrapped in plastic, lol), the FPR is leaking (unlikely it'd hold pressure), or maybe the injectors are stuck open.
Just in case anyone is interested, I'm attaching a FORScan capture.
Thanks
@SenorNoob ,
My guess is the one or two fuel injectors leaking caused the upstream O2 sensor to carbon foul (see uploaded pic). So, it was unable to read oxygen content properly, thus giving a false rich reading. The replacement O2 is responding as expected (with the rebuilt injectors).
I did follow @franklin2 's advice and added seafoam to the gas tank. Maybe I added too much?
Thanks
It will smoke if you add too much, though the catalytic converter might hide that.
@franklin2 ,
Well it is still smoking while it is running, and it doesn't smell exactly like gas burning. Also, the engine surges, or searches, while it's running. Almost like it is not running on pure gas. Which made me think there is too much seafoam in the mixture. It's currently sitting on half a tank. Do you think it would pay to fill the tank with gas to dilute the seafoam?
Thanks
You could. Put the good 93 in it and that should dilute it. Just sitting around with that seafoam in it is doing it some good. It's probably been long enough if it was going to do anything.
I think I've found the issue. Filling the tank with 93 octane didn't help. So, I went around unplugging some things to see if it made a difference. I unplugged each coil, one at a time, didn't help. Then I unplugged the MAF sensor. Cranked up and the engine ran normally. The wiring harness going to the MAF looks rough. So, I'm going to try and replace that, first. If that doesn't do it, I'll also replace the MAF.
The MAF sensor was the running issue. I replaced it with a NTK unit from RockAuto.
It still has the idling issue. I goes up and down until the engine heats up to around 140*. Then it smooths out and runs like a new truck. I'm going to drive it for a while to break in the rebuilt engine. I'll probably revisit the idling issue when the weather warms up.
Check the coolant temp sensor values on your scanner with the engine cold. It could be erratic cold telling the ECU to dump more/less fuel until it gets warm and balances out.
Hi @RobWigglezz ,
Per your suggestion, I started the truck while monitoring the temp gauge via the PCM scanner.
With the engine off, the temp read the same as ambient, 53*. I cranked the truck and let it idle. The temp climbed slowly.
At 77* the PCM switched to closed loop.
The idle remained steady (no going up and down). I stopped at 170*. The erratic idle usually smooths out at 140*.
The issue does not seem to occur if you don't hit the gas while below 140*. I'll try the test again when the engine is cold and hit the gas before it goes into closed loop.
I also have an issue with the alternator over charging in 15v - 18v spikes. When it happens, the radio turns off.
I'll post again after the next testing.
Thanks
Hello Everyone,
I tried the warm up test and revved the engine a couple times before it reached 70* (started at 48*).
It did the "up and down" idle thing.
While this was happening, I noticed the PCM went into "Open Loop - system failure" and the "Bank one Sensor One" O2 sensor stopped reporting voltage (0V).
I'm next going to focus on the B1S1 heater circuit. I don't think the O2 is being pre-heated properly.
Thanks
Hi All,
I pulled the alternator today and removed the voltage regulator. The brushes were severely worn, and it appears the dust was shorting the brushes together. I'm attaching a pic. I've ordered a replacement voltage regulator that includes new brushes.
Thanks
Hello,
The replacement voltage regulator did not fit. So I cleaned up the old one and reinstalled it and the alternator. The charge is steady, now. It should work for a while.
Thanks
Was one of the O2s bad?
Hi @RobWigglezz ,
No. they are both reporting voltage changes. Although, the downstream reads zero volts until the engine warms up a bit.
Thanks
