96 ford ranger 4.0 2WD rear passenger brake flex hose
Crazychris2572
California
My abs light came on after getting to work once my shift ended I went out and checked all the wheel bearing just to make sure that wasn’t the reason the abs was coming on then I made sure the brake reservoir had fluid then checked the lines this one flex hose has a tear I order a new one but I can’t find a video of some on replacing this they have a video of replacing the brake line that connects to the master brake but not to this flex hose
thats not a brake hose, thats your parking brake cable
The brake hose would be at the top center of the rear axle, drops down from the body and connects on top of the rear axle and then goes to each wheel cylinder via a hard line on the top of the axle tube
Omg I
omg thank you so much I was stressing cause I had my family telling me it’s a flex hose brake since everything I looked up looked like that thank you so much
