96 explorer t-case vs 96 ranger t-case?
Kevery
06/2013 OTOTM Winner
OTOTM Winner
Solid Axle Swap
Santa Cruz CA.
are the 96 explorer t-cases the same as the 96 rangers t-cases? did explores come with 3.0 engins with 4r443 tranys or just 4.0's with 5r55e tranys and 5.0 with what ever tranys they use?
I have a 99 ranger with a 4.0 and a 5r55e. need a t-case out of a 96 ranger because of the vss placement. I have access to a few explorers and was just seeing if I can get some info before I get down and dirty. hopefuly this make sence to you all. thanks for reading.
The Explorer never came with a 3.0. Period. Also, not really sure how that was relevant to your overall question.
A 96 Explorer case will work if it didn't have automatic 4wd (and I mean automatic automatic, not electronic automatic).
I was just curious about the 3.0 thing I figured they didn't. What is "automatic automatic"?
Any ranger or explorer t case (except maybe the AWD version) should bolt up just fine. I have a 94 ranger 1354M in my 99. The VSS isn't a problem cause its in your axle anyways so as long as the sensor is in or you make a good plug so the fluid doesn't escape in the t case an older model should work just fine.
The Ex case wont work. Its a 44-05 not a 13-54.
Yes, it will bolt up, but you wont have 4wd. The 44-05 uses a magnetic clutch to engage 4wd, the shift motor only works the high/low fork. If you get it to work, you will only have 2wd, 2wd and 2wd/low.
I think kevery swaped to a older Dana 60 that does not have the vss in it, that why hes looking for a t-case with it. I just kept looking in the local yards till i found mine.
If the Explorer has what Adsm is talking about, it will have an "auto" selection on the dash.
You don't want this:
You need it to look like this:
images
I have a 1354 in my shed that came out of a 95-97 Explorer my buddy parted out.
Oh... well any 96 and older would probably work then. But i thought they had switched to the Rear VSS by 95/96. Hmmm.
Wait no. nevermind the older ones are cable driven vs the newer ones that are electronic.
Not if its a 13-54. The Ex used the 13-54 from 91-94 on all models. They used it again on the sport and sport trac starting in 2001. The 44-05 was used on all v6 models from 95-00.
The difference in the 95-96 was that it had a true 2wd, 4 auto, 4low. The 97+ had 4auto, 4high, 4low. This was accomplished with a program change in the GEM, not with a 13-54 t-case.
well! I guess I got my answer and then some. ford78 knows whats going on. I have access to a bunch of explorers and not alot of rangers so I just wanted to make sure before I started striping stuff down that it will work for me you know what i mean. Thanks everyone.
when are you gonna get that engine in that explorer of yours. I'm planning on doing the same to my ranger and have been reading some of your threads. get r done.
Soon, I blew the trans yesterday, so its off the road now. The SOHC has taken out 2 4R55Es so far.
I saw the Explorer he pulled it from, it was without a doubt a 95-97 Explorer.
The Tech Library says:
picture.php
The tech library is wrong. The Ex came with Control-trac in '95. If its Electric shift, its a 44-05. The '95 Ex GEM can not control a 13-54. They are shifted different.
got it
