96 Auto Ranger Torque Converter Squeal?
fgiraffe
Hello all, just found this forum and looking for some info. I did some searching and didn't find anything that matched, so here goes…
I have a 1996 Ford Ranger 4L V6, 2WD w automatic transmission, ~145k miles.
A few days ago I got back from a road trip of ~200 miles. The truck drove fine, and then sat overnight. I was driving in the mountains, so I did turn the OD on and off a few times as terrain required. All was fine.
When I started it the next morning I had a near-constant high pitched squeal as soon as the engine started. I drove a few miles around town then parked it. The squeal diminished from constant to maybe 20% of the time. Took it to the shop today, thinking it was some belt problem. I hear the squeal now even less, maybe 5% of the time (maybe I have worn through whatever was squealing! :)).
My mechanic investigated and did not find any belt/pulley issues, and thinks it might be coming from the torque converter. He's hesitant to flush the tranny because it might accelerate any failure. I'm hesitant to pay the labor to drop the tranny without more info.
The truck runs and shifts fine. My gas mileage has been normal. No strange smells, no leaks, I do not have a blinking OD light. I hear the squeal in all gears, moving or parked. The squeal seems more related to engine RPM rather than moving speed.
Any thoughts or advice? Does this sound like one of the bearings in the torque converter has died?
Thanks in advance!
haha, thats very vauge. i can list about 50 things that could be. is the sound coming from the tranny? bearing is a possibility, but id fire it up without a serpintine belt to make sure its not the belt.
Thanks anyway. Yea, I know it's hard to diagnose stuff like this on the net. :)
Tranny shop thinks it might be a cracked flywheel, apparently this is not uncommon on this model?
Anything else preventative I should have them do while they have the tranny off doing this repair? Ideally I'd like to not have to drop the tranny on this truck again for a...while.
yea, rear main seal, dont forget! also wouldnt hurt to replace the trans filter
you could top up your exhaust bearing grease, and blinker fluid too.
