96 2.3L timing belt replacment
DixieStyle
Port Charlotte Fl
How do i replace the timing belt on my 96 2.3L ranger i have the cover off and im lost from here. a friend said to just tighten down the tenstionor and stick with the old one but they are only $30 and it has about an inch of play in it so its getting done. thanks.
On the 95-97 2.3's you need to line up the "DIAMONDS" at 12:00 o'clock on both the camshaft and oil pump pulleys. The crankshaft keyway should be at 12:00 o'clock also. Changing the tensioner is a good idea and cheap insurance to boot.
The easiest way is to tighten the tensioner bolt while the tensioner is out of the way (belt fully loosened), then you can install the new belt with the timing marks aligned. Then...........slowly loosen the tensioner bolt you tightened to hold it from putting tension on the belt and make sure your marks are lined up. IF they are still lined up, then turn your engine over BY HAND a couple of revolutions to make sure the marks are still lined up.
If they are then go ahead and tighten BOTH tensioner bolts. The one going through the spring (17mm), and the one threaded into the head (13mm).
Allen
Go to autozone or advance and get you a haynes manual, should tell you everything you need to know.
