95 later Ranger 4X4 Wiring Diagram wanted
TeamExploder
McClure, Pa.
I'm searching for a wiring diagram that traces from the switch on the dash to the t-case, want to convert the ex but need to see what all I'm going to need when I install 1354 t-case so I can change the t-case positions from the switch on the dash. Thank any y'all for your help.
Wiring diagram 96 Ranger 4x4 system
Here you go, this is from the Ford wiring diagrams, for a 96 Ranger. Hope it works out for you...
I hope your aware you have a different transfer case than a ranger. You have a bw 4405. If you want it to engage without the viscous clutch kicking in and out search for the brown wire mod. It will basically give you everything a 1354 will without the hassle of swapping it.
