94 super basic ranger renewal
JB3
finally back in a ranger!
Just bought this 94 as a replacement work vehicle, and need to fit it out. Could not resist as I love the 90s teal and its amazingly simple with manual everything
fairly complete and a good starting point to work off of
took a bunch of pics, I have some rust work ahead of me.
Body looks decent-
Inside is dirty, but should shine up nice with some cleaning
Bought it for the simplicity, manual trans, manual steering, no A/C, and 2.3, it can't get much more stripped down
Only rust on the body is a little area of damage on pass rear corner of the bed, and some starting wheel arch rust on the bed
You would never know from the way it sits that this is the rear suspension currently-
driver side-
passenger side-
or that the cab was hanging on one side-
truck only has 90k, im pretty sure it launched stuff from a boat dock and was backed into the Atlantic a few times. There is a very definitive line along the frame of rust
spare is basically as solid as a butterfinger
so plan right now is get rid of current spare, and all bracketry to keep a tire under the truck, then mount another wheel inside the bed.
On order are shackle and mount kits for the rear suspension, new shocks all around, and rear cab mounts. I need to get some cab bushings, but after that it should be a little safer.
Amazingly in the current condition it didnt ride all that bad. I thought all it might need was shocks. :D
chassis stuff arrived in the mail today! will be a fun weekend
cab mounts are unpainted folded replacement parts of pretty good quality. The spring stuff seems much more like OEM stamped and painted
some update pics-
pulled cap, pulled bed. this was possible alone but I wouldn't do that again.
the rotten cab mount also created some chafing issues between the cap and cab, but should be easy to touchup without too much work
I might also get some shock mount brackets while im at it, but I will see what material is left after busting off some rust
fortunately bed wasnt too damaged by the leaf springs, got lucky there
some overdue updates-
truck is on the road! replaced all hangars except driver front, wheeled down and painted top of frame with rust converter-
this is in prep for sandblasting and undercoating later
need to replace rear frame crossmember soon, pretty crispy
also driver side frame after the rear shackle is very thin, will need to beef that up soon before sandblasting. With those two frame issues welded in, the frame should be solid
other improvements were fresh fuel pump, new tires, new shocks, front brakes were awful, new front brakes, refreshing of rear brakes.
Dithering on the cap. Do I need it, do i not need it for work. There are arguments either way for the duties assigned to this truck. I do like the way it looks, which is unusual for me since I usually don't keep caps.
All depends on how simple a block and tackle system set up in my garage to hoist the cap off the ranger might be to build. Then I would keep it and hang it on the ceiling.
