'94 Receiver hitch. Will it fit?
Southern3.0
New Port Nowhere FL
'96
I found a Hitch off a '94 Ranger for cheap, I know the spare tire mount is diffrent between '94 and my '02 so I'm not sure if it will work. So dose anyone know if it will fit?
I'm not sure, but I think the only difference is in the spare carrier, not the frame. The newer carriers use a winch type system. If you decide to buy and it won't fit, I'm pretty sure it will resell here.
The only reason I can think that it would NOT work is if the truck it is coming off of is a flairside. Otherwise, it should bolt right up.
FRAMES ARE NOT DIFFERANT JUST THE BEDS
Well Hidden hitch has the same part number for '94 and '02, so dose Reese so Im gonna say it will fit.
Thanks guys.
