Sorry missed you previous post, have to unscrew fan Clutch to get shroud on.
Yes, fan shroud fits in two slots at the bottom and can be wire tied at the top.
What coolant are you running?
Most is already 50/50 pre-mix, so i doubt that's the problem.
When engine is warmed up and running feel the upper then lower rad hose.
Upper will be hot, and tight.
Lower should be almost as hot and just as tight.
Raise RPM while squeezing the lower hose, it shouldn't get very soft, a little softer maybe.
