- Mar 10, 2013
- Issaquah, Washington
I bought the truck 07/13, flushed out the Nasty cloudy green coolant out of it, put 50/50 in it. Blew the wheel bearings in 09/13, so truck sat on the back burner for a while. In early 02/14, I got the truck driving again and drove it for a weekend on a trip permit to do a few things before I sell it. I then decided against selling it, and did more maintenence on it. Then on Wednesday 3/05/14, I flushed out the old coolant, cloudy green again. I I then put some prestone coolant flush chemical in it ran it for maybe 45 minutes, let it cool down. I then drained the radiator, put straight water in (planned flush it to get all the chemical out), changed the oil with some 15w_40 diesel, new oil filter, new fan clutch and fan, new radiator cap, new air filter, new spark plugs wires cap and rotor. Started it up, let it warm up a little bit while I cleaned the crop out from in front of the truck, took it for a drive and ran it through second, and took it back home. Wasn't boiling over or anything when I got it home, so I parked it. I had my brother listen to it idle and we determined it was missing and my upper radiator hose was leaking at the radiator. I took that off, put it back on and tightened it down, and started the truck. There was A LOT of exhaust coming out and the radiator wasn't leaking so I turned off the truck after about 1 minute of idlimg. I checked one last thing in the engine bay before going in for the night, and the coolant was bubbling, not boiling. So I went to vent the cap to see what would happen, and it sprayed water out. I did the glove test and verified that it is a head gasket. The coolant valley under the thermostat is orange. It also has a new thernostat, forgot to mention that. I'm not sure if previous owners used head gasket sealer or not, but I do know the truck was gutless as he'll before the tune up, and still has issues with some hills before I knew I blew the head gasket.
