modelageek
- Jan 31, 2009
- Boston, MA
- 4.0 V6
- Automatic
Fuel pump is good.
Next check will be the neutral safety switch on the clutch pedal.
Thanks.
you said it cranks over so that means IT IS NOT THE CLUTCH POSITIONING SWITCH.. POST #10 MAKES SENSE YOU NEED TO DETERMINE IF YOU HAVE FUEL AND SPARK. post #12 has some good info but is jumping to conclusions. spray starter fluid or pour a few tablespoons of gas into the TB. if it fires at all you have spark. you also could test the wires for spark. if you end up having both fuel and a spark than it is most likely your crankshaft positioning sensor. A lot of times when the CPS sensor goes it throws a code for it. YOU CAN'T JUST SAY THE "FUEL PUMP IS GOOD". THIS FORUM WILL ONLY WORK IF YOU GIVE US DETAILED INFO OF WHAT IS HAPPENING. why do you think the fuel pump is good? did you test it? I will be glad to help you. I have a BB and get my emails immediately. give us some feedback as you test the truck and we will help. test for fuel and spark. a lot of times when you have no codes at all it is a fuel pressure problem.
