johnny71
- Apr 21, 2010
- Automatic
Well it looks like I'm overdue for some new body mounts on my Ranger. I started noticing my front right side bouncing when I hit bumps. Took a look underneath:
I also found that on the driver side, furthest back body mount, that the hardware bracket that is bolted and rivoted (anyone know why one side is rivoted and one side is bolted) into the frame has deteriorated.
So a few questions relating to body mounts.
1) Where can I find the body mount hardware cheap? Does anyone have information on bolt/nut/washer sizes?
2) Where can I find the body mount bracket that bolts onto the frame on the driver side near the gas tank?
3) Given how close the gas tank is in regards to the frame, would that have to be dropped and moved out of harms way to grind off the bolts and rivots that are holding the deteriorated bracket? (Please say no!)
Next issue are the I-Beam bushings. They are deteriorated as well:
Some questions:
1) The polyurethane replacements don't come with a sleeve. Is there somewhere I can buy this sleeve?
2) Are these bushings pressed in? If so what's the best method to replace them? I assume the whole beam would need to be removed from the truck?
This truck has 160,000 miles on it. Most people tell me its not worth doing this but I really want to get the most out of this vehicle.
Thanks
Some questions:
Thanks
