94 Mazda B4000, 2 weeks in..
Anyone know of any stock D35 equipped vehicles that came with manual hubs?
Ok, I got some Ruff Stuff engine mounts coming today. I'll post up once I get them in!
Also have D44's that are going under the knife with a 9" to match.. I also rebuilt my shocks, made a intake, installed a muffler. I also built my rear bumper/spare mount..
its all lies until we see some pictures!!! Joking nice truck its really coming along well :icon_thumby:
I was using my phone for the camera and that broke.. So let me get the D60 out tomorrow and get some real pictures.. lol..
I'm sure you know, but get a tranny mount to match the engine mounts. If the tranny can move but the engine doesn't want to, bad news!
Liking the truck, you're really rippin' along!
Yes sir.. I have 2 poly bushings, some 1 1/2" dom, and some 1/4" plate. I'm all ready for the trans mount. I am putting the engine mounts in first, then I am building the trans mount..
Thanks bud..
The intake is only temporary I needed room to tuck 35's at full stock location bump. I'll build a box for it. Which I did accomplish with a fire wall tub. I also had to move the ECU. :) Some people say you can't run 35's on a stock width D35 TTB.. Sure you can.. The only down fall is the weaker hubs.. Well I will upgrade to a full width D44 TTB setup shortly. This will work for now and prevent me for having to buy 33's. I won't be running 4 wheel drive unless its to get myself out of something hairy.
Now on some 2.5" Coil Overs.. I need to play with springs.
They are a bit too stiff. I have zero preload and I'm sitting 1" above my desired ride height.. I only want to have 3.5"- 4" of lift in the front. This will give me 8.5" of up travel still and anywhere where from 5-7" of droop depending on where I want to strap it.
I am working on tubbing the drivers side fire wall.. Its much more tighter then the passenger. I ditched the E-Brake pedal. I will make my own cable with a hand brake from a car eventually. If anyone has any suggestions on this, let me know. I am just figuring things out as I go.
pickup a trailer fender from a rural king type store....cut your hole and cut the fender down to fit
Are you talking about the firewall tub? I got it handled already. Not much needed to be taken out. As far as fenders go, I am going to trim the fiberglass to where it almost comes to a point on the bottom where it meets the door.
