94 Ford Ranger XLT 2wd Last odds and ends
Featured Build Threads
eloyc
Forum Member
Midland
TX - USA
Vehicle
Drive
2WD
3.0L
Well I got her up and running good but I'm looking for some chime ins on the last odds and ends I need to wrap up. Often enough on start up there's a puff of whitish/bluish smoke and then a bit of water trickling off the tailpipe, I've smelled the smoke and exhaust fumes and it smells just like regular exhaust to me. No oil and coolant mixing, not losing coolant, unsure if I'm losing oil. The valve stem seals are new curious if anyone has any advice on this. Im also getting a code 335 for EGR, if anyone has any advice on this too and where to start that'd be great. Last thing is I need to replace the front suspension bushings, if anyone has a link to a full kit or a list of exactly what bushings I need it would be greatly appreciated. The truck does start up every time and run smooth, sometimes there's a hardish shift into gear but overall she's a smooth ride. Hoping she last me a good while. Any and all advice is welcome. Thank you all greatly 🙇🙇🙇
You need to get it out on the road and get the exhaust very hot before worrying about anything coming out of the tailpipe. If this is a project I am assuming it has been sitting a lot, with the occasional ride around the block or the yard.
On the code, if you have a DPFE sensor, they have a high failure rate and can cause that code. It basically measures the exhaust backpressure in the exhaust feed line to the EGR valve, and lives a rough life doing that.
Thank you for the input good sir, you are a scholar
Upcoming TRS Events
Featured Ranger Based Vehicle
