94 4wd 4.0 transmission
It has been a long time for me but I believe recalling a large screwdriver inserted into the flywheel teeth to hold it as you remove each one
To the internals? Through the top cover. I've peeked inside but never been much farther
Where do you gain access. The bellhousing is closed up
Sorry, I was mixed up between two different posters
You will need a Ford manual
I have one on CD which I don't really need but you will need a computer XP or earlier to use it on, actually I'm not certain, it might work on windows 8 or others, I really don't
It is from before windows 95
Update
The Mazda is a 95. I think it has the sohv 4.0 engine. Can I use it in place of my ohv. I am not 100% certain. The old man can't find the keys. I got this from the vin#
What is the easiest way to remove the torque converter bolts
With it installed in the vehicle? Through hole where the starter goes.
