swtjames23
UPDATE, SOLVED 1-18-16: The problem ended up being caused by two things: Leaking plenum-to-fuel rail gasket and bad wires/plugs (not sure which, I changed both)
Hey guys, haven't posted in a while because I usually find my answers by searching the forum but not this time. My latest ranger is a '94 4.0 and it ran pretty good when I bought it with 250k on the odometer. PO says it was rebuilt but who knows. It had a high idle so I chased that for a while, fixed it. It has since developed a much bigger problem. It has a miss at idle but runs ok under light throttle. As soon as you give more than 1/4 throttle it loses power, cuts out, misses, knocks. It started out at 3/4 throttle or more but has gotten progressively worse.
So far what I have done (that hasn't helped):
New fuel pump
New fuel filter
New EGR valve and sensor
Checked fuel pressure at rail
Checked air filter
Checked plugs (visually, look good)
Checked wires (ohms checked out)
Checked coil (ohms checked out and each plug has spark)
Cleaned and checked MAF (voltage checked out at idle)
Cleaned IAC
Replaced fuel filler neck (unrelated, just saying
Checked vacuum (~22)
Hoping you guys can give me some ideas as to what to check next. Does it sound like an internal mechanical problem? Like a burnt valve? Or would a leaking intake gasket cause this? Keep in mind, it didn't do this when I bought it a couple months ago, so maybe I did something to cause it?
BTW no CEL and no codes
New fuel pump
New fuel filter
Checked air filter
Cleaned IAC
