RonSerling
- Mar 25, 2013
- 4.0 V6
- Total Lift
- ummmmm 4" could be 6 but its a TTB and the little bugger varies from time to time !! LOL
- Tire Size
- 33/12.5 15
Good day All,
I have a 93 Ranger 4.0 4X4 with 780K miles on it. It has been a great truck but as time goes on the engine has gotten quite tired out. I am looking at replacing it and a friend has a 99 that got t-boned but the engine in it is in great shape with only 98K miles on it and runs well. In looking over his and comparing to mine it looks as if his top end is completely different. His has a poly type intake with an egr where as mine has aluminum intake no egr and a set of Cal compliant headers on it but other than that they look the same. Question here is can I remove and replace his poly egr system with my aluminum one and will it work ??? Are the intake systems interchangeable without any major modifications and if there are any mods needed what would they be ?? I would appreciate any info that would help me make this decision as I want to do the swap as soon as possible. Thanks Edit - OK I may have confused the situation here a bit !! What I am asking is are the long blocks the same, not including the SOHC engine, whereas will all the accessories and the intake from the 93 bolt on to the 99 engine in the same manner ? Are all the sensors in the same locations ?? Will the motor mounts from my 93 bolt on to the 99 long block correctly??
