93 ford ranger bbk instacharger question
freakypierced1
Hurt, Virginia
I'm installing a supercharger on my ranger and right now i'm hooking up the boost/retard control box. It says I have to hook into the crank position sensor wires. This may be a dumb question but are the wires coming from the cps the only ones that color? I want to make the connection near the ecu so I don't have to route a bunch of wires. I found two in the huge bundle of wires that run into the ecu that are the same color but I was hesitant to splice into these wires until I knew for sure these were the ones. And does anyone know where I can find a wiring diagram online? thanks!
Find a wiring diagram (Ford EVTM books are the best source) for your year truck and look it up. It will give you computer pin number to tap into and everything.
