- Dec 11, 2008
- Age
- 34
- Lancaster, PA
- 2.3 (4 Cylinder)
- Total Drop
- 3 front 5 rear
- Tire Size
- 225/60R15
Ok then here goes...Bought my 93 Explorer Sport 2wd 5-speed 4.0. After a couple weeks, very once in a while while going up a hill or giving it a decent amount of gas, it would sputter a tad and hesitate a little. sometimes the CEL would come on, then go off when I got off the throttle. Then it started sputtering and popping at 3/4 pedal to WOT, so I would baby the throttle and it would run decently. Now...I start it and I idles ok, but has little power and almost sounds like its running on 5 cylinders (which it isnt, i checked the voltage to each one). So far I have: cleaned the MAF, replaced BOTH o2 sensors, dumped in fuel system cleaner, new plugs and wires, new water pump, new oem air filter. I'm lost as to what I can do. anyone else have this problem? How did you fix it?
