Wanted '93-'94 4.0 PCM needed.
paul44224
Stow, Ohio
I have a '94 Ranger, 4.0, automatic. I need a PCM for my Ranger. Tried the local yards. No luck. Only '93-'94 4.0 will work. The '95-up are OBD-2. Mine is OBD-1. Thanks !
Will a pcm from a 1993 navajo with 4.0 and manual trans work?
Check car-part.com
These are not expensive to ship
Select "computer box engine" as the part you are looking for
Then you can select engine size and MT or AT(automatic)
2WD or 4x4 doesn't really matter
But "they" might sell 2WD for less money, lol
Unless your computer has been physically damaged these units are pretty bullet proof, just need the 3 capacitors changed and they are good as new
+1 ^^
That would work, only thing to watch out for is if its from a Calif 4.0l vehicle, these required EGR and Cam sensor hook ups, not required in other States in those years
+1 ^^
its not from calif
I've got a 93' xlt 4×4 king cab I'm wanting to sell. It's got the 4 liter V6 with a standard transmission, power windows cruise control. Everything still works except for the AC. And my father-in-law popped out one of the wing windows. Still runs and drives. Interested?
