93Ranger4x4
Alright fellas, the time is getting closer to doing my swap. I've got a 93 splash reg cab 3.0 5 spd 4x4, i've got a parts truck which is a 93 reg cab, 4.0 5spd 4x4. I just wanted to post here and make sure i know what i need and dont need. I know i need the engine, and the engine harness itself and the computer. i looked at the 2 main plugs that the engine harness plugs into on both trucks and they are identical, also looked at the fuse box under the hood and all the fuses are in the exact same spot on both trucks. My question is am i going to need any other wiring from the truck? To me it looks like a direct swap in, plug and play. I'm going to use the 4.0 motor mounts,engine tranny(tranny needs a slave cylinder and clutch), 4.0 computer and use my t-case and save the other for a spare. Are the slave cylinders in the trannies the exact same? if so that will save mesome cash there. just lemme know if i've got everything correct before i dive into it. Oh and yes im going to use the 4.0 rad as well.
Any info is greatly appreciated.
thanks,
93ranger4x4
thanks,
93ranger4x4
