93 3.0 5 Speed
jarmo
King George VA
I got a 93 3.0 5 speed 4x4. Something internal has broke in the trans. Looking for a replacement, but cant find any cross reference as far as what years, engine, etc. I found a good thread on a 4.0 just down from this one, but nothing on the 3.0. I found 2 Rangers locally that are manuals but havent gone and looked yet because i dont know what will work. Also need to know if a 2 wheel drive will accept the transfer case. Any help greatly appreciated.
No, on the 2WD question, you need a 4x4 transmission
You can use an M5OD-R1(M5R1) transmission from a 1991 to 2008 3.0l Ranger or Mazda B3000 4x4
Any of these years will bolt to your transfer case and 3.0l Vulcan engine
Your speedometer cable comes from transfer case so no worries there
(if you ever change transfer case it must be 1997 or earlier or there would be no speedometer cable hookup)
Must, of course, be from a 3.0l engine since the bellhousing on these transmissions can't be swapped, its part of the main case
Only difference over the years will be the Reverse light plug on the transmission, so pull your reverse switch out and put it in the "new" transmission if plug is different, might not be, but pull it off the old one in any case, free spare switch, lol
The 3 rubber plugs on the back top of these transmissions could dry out and leak ATF(these manual transmissions use Automatic Transmission Fluid, heads up), so give the plugs a good look before installing transmission, replace if you see they are leaking
The 2001-2008 M5R1s have an extra sensor(OSS) that you don't need, doesn't hurt anything just leave it unplugged
Here's what came up in Va.
Transmission Assembly
REMAN UNIT 3-YR 100K WAR CORE CHARGE
X​
GPT400
$1626​
M and M Auto Parts, Inc. - RTN, VARA, MWRP USA-VA(Stafford) Request_Quote 1-800-586-5492 / Chesapeake 1-757-447-6051 Request_Insurance_Quote
Live Chat
70​
1994
MT, 4x4, 6-183 (3.0L),3.0L,MANUAL TRANS,4X4, 132K
132,023​
A​
AAR009
$700​
Fleetwood Motors Company VARA USA-VA(King-William) Request_Quote 1-800-800-6826 Request_Insurance_Quote
Live Chat
111​
1993
CORE PARTS ONLY 4TH ONLY, STOCK# #52076, TAG# #52076
X​
LP52076
$100​
G & B Auto Parts, Inc. USA-VA(Floyd) Request_Quote 540-745-7401 Request_Insurance_Quote
Live Chat
Thanks for the reply guys. That narrows it down for me. The lady that has the trucks said one has a blown motor and dont know anything about the other. Cant even tell me if they are 3.0 or not, lol. Guess ill take a ride and see. Thanks again
If you're still looking, I have a spare m50d-r1 with a 4x4 tail in VB.
