Duane867
93' 2WD 2.3L M5O-R1
Recently ( last weekend ) I replaced the slave cylinder, throw out bearing, clutch and pressure plate.
Before the repairs the clutch was not slipping but hard shifting in to gear and over a certain rpm the trans would create a noise like rocks in a can. Usually right when it was time to shift under normal driving conditions ( drive it like a grandma ). After the new installs I thought I was all set. Drove away and still had the rattle. When I had the trans removed I did note a small amount of end play on the input shaft. I would say near 1/16 - 1/32" guestimated movement from side to side and up and down right at the tip.
Bought the truck used three weeks ago knowing it would need a clutch and timing belt.
The belt smacks the cover a little but I am positive it not the noise I am hearing because I can hear and feel it a little right above the shifter.
I fancy my self an OK mechanic with skills enough to solve my own problems most of the time but this damn thing has me wondering. after the truck has set a little while then I take off it does the rocks in a can bit, BUT if I have been driving a short distance it stops and dosen't do it again until I let her sit for a little while ( hour or so )
I did note that when I removed the shifter the kind previous owner was gracious enough to remove the shifter ball plastic bushings and not reinstall new ones. ( engineers know pen to paper but squat about real world physical labor and common sense ) The truck runs like a new truck. Really, its so quiet I have to double take to make sure it hasn't stalled at red lights once in a while.
Hope this isn't what I think it is though..... shaft bearings or syncro's.
Its sort of like well rocks in a can. Only happens under acceleration.
When the clutch is depressed it does go away but I can hear it wind back down to where it stops. I notice it audibly through 3rd gear.
I have not checked the fluid level, the rail plugs are seeping a bit but nothing major.
Any takers ?
Any takers ?
