93' 2.3L M5OD-R1 5spd..... rattling rocks in a can noise....
You took it upon your self to make it about you. No one insulted you until you had a public brain fart.
Truce, have a good weekend....
lol ok dude. My first post apparently didn't effectively convey the joking tone I meant it to, maybe I should have used a smiley. But I don't think your wild accusations of me withholding information were called for.
You have a nice weekend too. I'm going to the river and getting drunk tomorrow.
my truck makes this sound, well.... sounds like a tin can running around the engine o_0
it'll make the sound when Idl, and then it gets faster when you accelerate. I think it may be a loose piston, but I could be VERY wrong.
Very unlikely its the rings or a wrist pin vibrating.
Unless its been rode hard and put away wet one to many times that is ?
Loose pistons to me equate to bad wrist pin needle bearings. ( where the connecting rods make connection to the bottom of the piston. ) Worn rings can some times rattle around the piston at speed.
next time it's doing it while you're sitting there idling try putting a little pressure on the clutch, if it goes away it's probably a throw-out bearing.
