92 ranger 4.0 to 92 v8 5.0 bronco wiring help
Warwaggon92
ok so heres the deal. i have a 92 ranger xlt that the engine died and i needed more power so i did the upgrade to the v8. found a donor vehicle that was a 92 ford bronco with an e4od trans.
all the wrench work is done. now its time to do the wiring, im using 80% of the bronco wiring harness (because of the e4od needs it being its electronically shifted and the dash/speedo from the bronco) . the only thing im not using is the steering column wires that actually go to blinker and all that and the rear wiring harness. and the door harness. this was an almost perfect donor vehicle.
so now comes time to splice. anyone is in nj or close to southern nj and wants to make a few bucks let me know.
so i basically need help with the color codes and what i should splice what where. (im an electrician however im a novice at dc and anything car related.). anyone here know where to start??? i know with the right info ill be able to get all the electric done in a day or 2. its just knowing what goes where.
I need the dash harness swap so I can use the e4od trans. I actually needed to use the speedometer of the Broncos because the trans works electronically. So I basically have to hook up the rear and the steering column to the right wires and everything else should work.
Yes, 1992 Bronco was first year of electric speedometer, learn something new every day
1992 and later Broncos upgraded to an electronic speedometer connected to a Programmable Speedometer/Odometer Module (PSOM). The speedometer cable and VSS were removed from the transfer case and the RABS Sensor on the rear differential became both the VSS and 4-wheel Anti-lock Braking System (ABS) Sensor. The AC Frequency signal goes through the ABS Module to the PSOM, for speedometer/odometer functions, and is then sent to the Cruise Control and PCM." by Seattle FSB
You will need the PSOM as the interface, it should be on the back of the speedometer and its output will go to speedo and PCM(computer)
Rangers got electronic speedos in 1995 but didn't use ABS sensor on rear axle until 1998
