woodi
- Apr 8, 2015
- Automatic
So last night I picked up a 92 Ranger XLT took it for a pretty long test drive, it started right up and ran fine, seller says engine runs great, doesn't leak any oil, why would I have any reason to believe otherwise, seemed like an honest guy. Claims plugs, water pump, oil was all just changed. I fill it up with gas at a station right up the road and when i go to leave it stumbles a little when it starts and worries me but drives the 50 miles home just fine. I get home let it sit for about 20 minutes then go to move it in the driveway and it starts up and idles rough, go to move it again a few hours later and it'll hardly run. Fire it up this morning and again the idle is really low and rough but it drives okay, drive it to work which is 9 miles up a steep canyon and the cel flashes on and off a few times but it seems to pull up the hill fine. Go out this afternoon to try and look into the rough idle since it was bugging me and it starts, runs rough for a few seconds, stays alive if i give it gas but sounds rough, I let off the gas it stalls and now it just cranks and cranks and won't start at all.
Did I just get scammed? Where should I start? is there something obvious that would allow it to idle fine when warm but really rough or not even start when cold? Exhaust when it was running seemed clean to me, no indication of it burning oil or coolant, I hear the fuel pump click on for a second when I turn the key on then click back off. Haven't really dug much further than that, it's snowing and not the best time to be working on it. Is there something the seller could have done to make it run fine for the test drive even though the engine was almost dead? Thanks for any help.
