I bent up some hoops real quick to get an idea of clearances under the hood. I used some 10" Fox emulsions for an idea because they have the same compressed and extended dimensions as the Kings I want to buy. Passenger side has plenty of room and won't be an issue at all. On the drivers side I will have to lean the hoop out slightly to clear the brake booster. The shocks will still maintain a slight angle inward at ride height. For the bar across the engine I'll just have to shorten the bracket holding my MAF and air filter a few inches.
The debate I'm having at the moment is how much of a difference I would notice going with a dual rate spring setup. Would it be worth the extra $160 on only a 10" travel shock? I could always change out the springs later on as well.
