92 ex 4.0 to 87 BII 2.9 swap
My mess of adapters.
Here are my notes, i hope it helps out a lot, maybe makes it easier figure out the 92 wires.
ronclark, Thanks!
That is great! I can deffinately use those notes. Now I just need to get to the salvage yard and get pigtails for the BII side of the adaptors, and check for differences between 92 and 93 Exp 4.0 EVTM colors.
I might just make some progress on this thing.
okay here is a few pics of my wiring between my 89 B2 and a 91 ford explorer
most wiring was between the bronco II dash harness plugs and the 4.0 ecm plugs
heres my 2.9l fuse box you can see the alternator wires are attached close to that
youll want to use the 2.9l power distribution box and that alternator harness
all the other wiring was on the drivers side fender
heres the jumper harness i made that connects the one main plug coming from the 4.0 ecm harness (brown plug) to the bronco II harnessthat runs to the dash (black plug and Grey plug)
n heres the other bronco II plugs( bottom 2 grey and black are orig 2.9) (the top one was from the 4.0 harness) they go to the transmission and engine gauges
i used my bronco II engine gauge wires.oil pressure, temp, oil level
hope i helped a lil
Babybronco89, great pics! Looks like a clean setup. Although it isn't quite my application, it is helpful to see what you did. I'm sure there are others who need to see it, as well. Thanks!
yeah the harness i made is def the cleanest part :D all the other stuff is coverd in oil crude n grime.
but i cant imagine the wiring on the older 2.9 to be that far off
the 4.0 ecm wiring and harness is all pretty much contained by itself with only a few wires braching off the engine harness to go to things in the dash like tach, gauges n a couple fused circuts.
so those would be the only things id think youd really have problems with during the swap
hope i helped
I got the 2.9 doner harness yesterday from the salvage yard, to build the adapter with. Now I'm working on the wiring file that ronclark graciuosly provided, adding 87 BII info, and 92 Explorer info. I think, if ronclark doesn't mind, I'll post it when I'm done. (after testing it, of course)
Then, if someone wants to add info from there swaps of different years, we could build a nice little 4.0 swap data base. Maybe post it in the tech section.
I'll be watching this one...think I'm about to take the plunge.
Thats fine with me the more info we have one swaps the easier it will be for everyone.
if you need anymore copies of the EVTM or questions let me know. I'll help if i can
Thanks ronclark!
I think on my application, I'm going to add the wireing numbers, and if I can figure out the connector #'s, I'll add those too.
This could end up being usefull to others! ;)
My EVTM has all the conector numbers and locations
Sent from my myTouch_4G_Slide using Tapatalk
ronclark, I'm sorry, I meant on to the file that you originated. I was adding the 87 BII wiring color info and also the wire numbers and trying to find the conector numbers as well. Just extra info to help make it as easy as posibly for any body that follows. :)
hows your swap coming along any updates?
Eh, sorry, I have been delayed. I just moved to a new city, and started a new job that is very intense, and had to put it on the back burner. I brought all the essentials with me, so as soon as I get a new part for my chopper to ride so I can use it as my dailydriver, Then I can start dismembering the BII.
Actually, I think I should build the adapter, first as well (duh). I have everythng I need, just been too busy to get my $#!* together.
I DID do the research and put together the wiring colors/numbers, and connector numbers and added them to ronclark's wiring file. I just need to actually apply it to be sure it is correct and works the way it should, before I feed anybody info I haven't verified.
I know it sucks to wait on other people's lives....sorry. I'm doing what I can!
I'll let you know as soon as I get some results!!
Thanks for the interest!!
its all cool, we all know how life can be.
Featured Ranger Based Vehicle
