92 4.0 M5R1. New clutch not working. Can I extend the pushrod somehow?
calebrk
va
As the title says, I'm wondering if there's a way to extend the pushrod that links the clutch pedal to the master cylinder. I recently replaced the slave cylinder and the clutch. I've bled the system as prescribed in so many places. I removed the master from the truck twice already. I inverted it, pumped it and tapped the line. I've bled it in the truck using the bleeder valve probably 50 cycles now. It seems so close but still not right.
I feel if the push rod was a little longer it would give me the amount of pressure needed to make everything work. Is there a procedure to do this, does anyone have a way to engineer it themselves, or do you have other ideas?
Thanks in advance for any help
Take the little rubber stopper off.lol Gets you 1/4" more travel.lol
Sent from my DROID RAZR using Tapatalk 2
