As the title says, I have to go through a rather weird process to engage 4wd.
I recently bought this 91 2.9l 4x4 Ranger for my winter beater. It has the automatic hubs and transfer case (which are 2 things I was trying to avoid, but the price was soooooo right). In order to get the truck to lock into 4x4, This is the process.
Select 4x4. Shift to neutral/hold brake, engage 4lo. Drive for a few feet. Back into neutral/hold brake, disengage 4lo. Then the 4hi stays engaged.
And as usual with these push button Tcases, Sometimes i can hit the buttons and nothing happens at all.
If I just push the 4x4 button and drive on, The light comes on, you hear the shift motor do its thing, but the front doesn't lock in. Not sure if it's related but there is a squeaking noise that gets faster as you go faster, i've had several people on the outside/inside of the vehicle trying to help pinpoint it, The consensus is "the front".
I did some research and came up with a ton of results but nothing exactly like my issue. Any one have an idea? I was assuming its a hub issue, but then why would 4lo make it work?
