00srad600
i have a 91 ranger 2.3 changed the head gasket a month ago. it was running fine fine for a month. now im burning oil and i keep finding oil in the upper intake any ideas.
The pcv is pushing oil but I fixed that and still getting oil in the intake right by the intake tube
There isn't any white mist when I pull the hose on the valve cover
Ok so is there anyway of changing the valve guide seals without taking the head back off
Yes, there is the compressed air method and the rope method.
The changing of the valve guide seals is the same for either.
Remove valve train assembly/rockers
Remove spark plug from each cylinder(only 1 if dual plugs)
Here is the difference in the two methods
Method 1
Rotate crank so 1 piston is at TDC both valves closed
Put compressed air in that cylinder via Spark Plug hole, this will hold the valves closed while valve spring is removed and new seal installed.
Method 2
Put piston about 1/2 way down cylinder, feed appropriate size rope into spark plug hole, couple of feet will do, rotate crank so piston compresses rope against valves to hold them in place, remove valve springs and replace seals.
Rotate crank backwards and remove rope.
Repeat for next cylinder.
x2 though, I can't lie, I've never wanted to try the compressed air method. Even WITH all the right tools...
... Only due to me NOT KNOWING how much pressure it needs and scaring the living crap out of myself by semi compressing my entire cylinder head!![]()
