- Aug 15, 2007
- 2.3 (4 Cylinder)
- My credo
- vertical and above ground
To check your PCV valve for proper operation, start the engine and let it idle. You should be able to place a postcard over the oil fill on the cam cover and the PCV should put a slight vacuum on the postcard and hold it in place.
No vacuum means the PCV is overwhelmed or plugged, or the passages or separator are plugged. The PCV is in the largish hose coming from under the intake manifold. It is 'in-line' with the hose, where two pieces join together near the distributor, or just behind the alternator. Pull apart and check the valve for 'rattle' by shaking it. Check that the hose leading from there to the underside of the intake manifold is un-plugged, and in place.
To change the valve stem seals, you'd have to compress the spring enough to move the cam followers out of the way before compressing the spring to remove the keepers. If you do it, wear gloves, or be prepared to have your hands cut by the sharp edges of the lobes and/or cam support bosses. The rope method works, and the air method depends on two things: 1)having the piston at TDC, and 2)being able to jam the crankshaft from turning, such as by putting the transmission in gear, not available on automatics.
tom
tom
