Broncoman1532
i just did the efi to carb swap. everthing went ok, i also redid the heads and everything on the top end. its a 302. the motor runs great while in park. while under a load it chokes andd falls on its face. what should the fuel pressure be at, i have a regulator on it but its maxed out at 5 psi. should i run something bigger or could it be the carb
