Wanted '90-'94 1354 Manual Shifter/Linkage
joenorthcarolina
Hello everyone.
I'm looking for the 1354 Manual shifter/linkage that will fit 91-94 Explorer.
If you have the boot and floor plate, I'll take that too.
Thanks for any help !
I just swapped a 1350 for 1354. One from a FM146/M5OD with 1350 isn't hard to make work if you have access to a vise. They are far more common in junkyards.
Just flatten the curves behind the pivot point and use a grinder to cut the notch out another 1/4 inch. Good luck!
Do you know if the big bolt that secures the linkage from the 1350 will fit the 1354 ?
Can't say for sure, but likely. The thread on the M5OD extension housing is the same as the FM146.
Y'all are not going to believe this. But I just got the dual shifter/floor plate, shifter/linkage and bolt for $90 shipped !
WOW !
I called every junk yard on car-part.com and found one lucky yard.
I can't believe it.
