pulled timing cover off.appears someone put a new belt on before i got it.if the engine is at tdc the cam sprocket pointer is at the top of the engine and should be at the bottom.how do i make 100% sure i have the engine on the compression stroke? i can feel the piston at the top of the cylinder.
Hahahahaha! Yep, that's your problem.
The cam sprocket pointer needs to be at the 5 o'clock position for the engine to be timed properly.
I say, take your timing belt off.
Align crankshaft according to it's timing mark by slowly tightening the crank bolt (doing it slow keeps it from getting TOO tight).
Then, by tightening the camshaft bolt, turn the sprocket until the alignment mark matches up with the middle pointer on that back part of the timing belt cover.
Don't worry about aligning the auxiliary shaft sprocket. It doesn't turn anything except the oil pump on the '89-'94 model years.
Now install the belt. Once you get the grooves lined up on the crankshaft sprocket, pull the belt tight and get the grooves seated on the auxiliary sprocket. Now pull tight (but not enough to turn the engine, haha) enough and seat on the grooves of the camshaft sprocket.
Then loosen the tensioner and let it take up the slack.
Now comes the most important part. Double checking the correctness of the alignment marks. I like to do this by, again, tightening the bolt on the crankshaft slowly. Do two full turns of the crankshaft and see if the camshaft and crankshaft marks line up to their indicators. If they do, GREAT! If they do not, then you will need to adjust the belt by one notch on the camshaft. Repeat the test. If they line up now, go to the next step.
Now you can put everything back together.
Oh, and be sure to tighten the tensioner bolt down, so that the belt cannot get slack if you rev the engine too much, and consequently jump a notch.
Last, but not least, let us know how it goes!
