2ruble
- Jan 3, 2017
- Loganville, GA
- My credo
- "Don't trouble trouble until trouble troubles you"
So this was a Warn rebuild kit (just orings) and it included two of the D35 orings (measurements all over the place) and two of the D28 orings - which are as follows according to our digital caliper.
Measuring the outer diameter of the hub (which is the inner diameter of the ring) yielded a measurement of 3.195" - the oring is .125" thick (1/8") and right at 3.25" (3 1/4") - which in following the measurements above doesn't exactly fit because of the flexibility of the oring under measurement. In any case, if I were to look for orings in the future for a D28 without having part numbers or calling Warn I would order, if they have it, 3 3/16" x 1/8" ------ And if nothing else then 3.25" (outer diameter) x.125" as it's probably good.
