88 ranger brake light on permanently
baxtej44
Omaha, Nebraska
okay, well 1st gen ranger. "brake" is lit up on my instrument cluster
it normally just came on (sometimes, not all the time) when i set my e-brake. now it's on for good it seems like, it's been lit up everytime i turn the truck on, and i tried setting my e-brake then letting it release, doesn't solve it.
is it a code reader issue? corroded wires? grounding issue? e-brake cable/pedal issue?
check the switch that is up in the park brake pedal assembly.
then make sure the brake fluid is full.. if its low top it off with DOT 3 only
with a voltmeter or an ohmmeter.
voltmeter:
there are 2 wires coming off the switch, with the park brake pedal released there should only be voltage at 1 wire- do this check with the switch plugged in.
ohmmeter: remove the connector from the switch and put your 2 probes on the pins of the switch, it should say OL
