crazyjp
- Dec 16, 2014
- Automatic
OK so this isnt quite an emergency but it is a big deal and is probably making me burn more gas then i need to but lets get down to business
I have a 1988 Ford Bronco 2 Eddie Bauer Edition 2.9l Fuel Injected Automatic with the manual 4X4 on the floor
When my truck first starts up id say it runs pretty good for a 26ish year old truck [other then the fact the tranny probably needs atleast a flush and fresh fluid (or to be junked)] but after it starts getting warmed up it tends to run like shit still drive able but the acceleration and general power is horrid but like i said still drive able. like for ex. when i push on the gas to get going from a stop it takes a while (say 0-25 in like 25 seconds with the gas pedal push about half way down)and has a deeper sounding growl to it then the higher pitched roar when it first starts up and this problem becomes very noticeable when towing a 4x8 trailer with a small riding lawn mower a push mower etc. it fells like i'm trying to pull a semi which i know shouldn't be as much of a problem as it is. so any ideas would be greatly appreciated.
things ive already done
New Plugs and Wires
New distributor cap and stator or what ever the **** that think that spins is called
New Coil
New TFI Module + Relocation kit with heat sink and added fan (due to stalling after 20-30 minutes of driving and not starting till cooled)
All new fuel system (except for lines and injectors did run some injector cleaner threw it though doubt it did anything)
Punched a hole threw the CAT with a pipe (don't tell the cops)
Put a glass pack on (not to fix the problem but to replace the fact that the muffler was shot and didn't have the extra 10 bucks for a new muffler so glass pack)
lots more parts but none that should affect this issue
By new fuel system i mean 2 Fuel pumps 1in tank one on frame rail new gas tank and fuel sending unit All 3 fillters replaced and plenty of fuel pressure at the rail 35-40psi
New Plugs and Wires
New Coil
