88 b2 crawler build
Side shot. You caqn see how much I pushed my axle forward. New Locker is suppose to finally ship today, not sure if it will. Ordered it last week. 34 10.5s on it in this pic but I just bought 36 14.5s so hope to get those on soon. I need rear spring ideas. What are people using for decent lift like 3 inch and good flex. I have 2 inch blocks too.
88 b2 crawler build
Shackle angle looks a bit steep itll make highway driving suck.Id slide the shackle mount back and up about roughly an 1" (1/2" back 1/2" up). You will loose some droop but lots of droop and little uptravel makes highway life hell I tried it once and yeah no never again.
Also you said you had a square tube driveshaft? Take it out until you get lockouts, they dont balance well and will ruin your pinion seal at minimum.
I didnt read what axle you 30 came out of but if you put TJ shafts in it you get a u joint almost identical to a d44.
The square tube only goes in when I'm on the trail. And yeah they're super long shackles. But that's why I was asking about rear lift springs. Just found out my locker won't ship till Monday. I ordered rhis thing over a week ago. Never doing business with this place again
Do you have any closer pictures of the leaf and shackle hangers? Also did you run a cross member between the front hangers?
Front leaf and shackles or rear? And I bought a trail gear spring hanger for a Toyota sas and made it work. It has a crossmember on it
The rear hangers
88 b2 crawler build
You can see the front hanger in there
88 b2 crawler build
Mock up
88 b2 crawler build
Welding
88 b2 crawler build
Welded
88 b2 crawler build
Leaf spring mock up
88 b2 crawler build
88 b2 crawler build
88 b2 crawler build
88 b2 crawler build
88 b2 crawler build
Tires I.just picked up
88 b2 crawler build
work looks pretty good man!
but dang thats a lot of leafs!!!!
I dont like how that front crossmember/hanger assy is welded on... Needs some reinforcement IMHO.
Thanks for the conpliment and yeah I think its a 7 pack. And there is gonna be tube on top of the hanger inside the frame rails with a stinger coming off that
They're super soft but flex awesome. I need to get 16" shocks for the front. My 12"s max out really easy
Thanks to adsm08 I got new door parts so I can finally roll my window down again
88 b2 crawler build
300 dollars and 3!! WEEKS! after I ordered it, finally showed up today. Also got the titanium center pin and ne thrust washers with the locker
88 b2 crawler build
And just another pic of my 36 14.5 15 tsl's I picked up for 550.
88 b2 crawler build
All this should be installed this weekebd and I can finally see how it drives on the road!
