turboranger2.3
- Oct 26, 2010
- vancouver island. bc
- 84 ranger 2.3 t
10 - separator code
11 - clear codes
11 - clear codes
kimcrwbr1, lots of good points, BUT.. ford does not have volitile memory.
Meaning it does not loose its memory. erases after 40 starts
To re-set memory faster ,touch bat. negative to pos. with one terminal of battery diconnected. folow. ? It discharges the capacitores , instantly.
ITS not the smallest code, it the first of the string of code. follow, and allway hard fault first , KOEO THEN , KOER , THEN MEMORY . .
Adaptive learning stratergies. takes the average reading of a sensor and uses it.
to compensate for irregularites. follow
Just by driving it , it will re-learn on its own.
Just takes longer.5-10 min. it could run like crap at first. but it will go away
MANY PEOPLE HAVE HAD THERE BALLS BUSTED BECAUSE THEY DID THINK THERE REPAIRED THE RIGHT SENSOR. THE COMPUTOR HAD NOT RE-LEARNED YET.
Remember ford trained monkey.talking. ASK ANY QUESTIONS.
