cedave
I have an 87 2.9L V6, auto trans, 2wheel drive, dual tanks. I've changed the fuel pumps in the tank and the HP pump on the frame rail, changed fuel filter, the spark plugs and wires, changed the fuel pressure regulator (napa), changed the MAP sensor, changed oil & filter, changed air filter, but the truck still runs like crap, seems like it is missing real bad. It starts up just fine but has a rough idle and some times after idling for a couple minutes the rpms will slowly surge up and down then it will eventually die. It doesn't do this all the time though, some times it will just sit there with a rough idle and not die. When I try to rev the engine it will bog and hesitate and then eventually rev up. Has anyone out there experienced these symptoms? What do you recommend? I'm at my wits end with this thing. It used to run really good!!!!! Also, the truck had sat for several years before now, so i drained out all the old gas in the tank when i changed the in-tank fuel pump (the old pump was totally seized up). The inside of the tank looked very clean. Please Help!!!!!!
